How to Paint-On Porcelain Tile Sealer How to Paint-On Porcelain Tile Sealer
Paint Pan
Gloves
Brush
Roller
Paper Towels
Porcelain tile sealer is required whether you are installing porcelain tiles on a floor or on a wall. This article will discuss the proper way to apply the sealer in order to ensure it is properly adhered.
Step 1 - Preparation
Pour your porcelain tile sealer into a paint pan. You can also use another shallow receptacle. Just be sure that it is easily accessible during application.
Step 2 - Brushes
Submerge your brush, roller or mop into the porcelain tile sealer so that it is completely saturated. Plan to have a few different tools on hand so that you can switch to a different tool if you find your first choice is not working properly.
Step 3 - Application
Apply the sealer generously all over the tile surface. Make sure that there is a good amount on the brush at all times to avoid streaks. If you are applying porcelain tile sealer to a floor, start in a far corner and continue back towards the door so that you are not trapped.
Step 4 - Drying
Wipe away the excess sealer with paper towels after you allow it to dry. Usually, the drying time is only a few hours.
