How to Plan for Your Porch Roof Addition How to Plan for Your Porch Roof Addition
Paper
Pencil
Computer Software (Optional)
Internet Access
Computer
Building a porch roof addition is not an easy project because there are many different types of considerations that should be planned out. A porch addition will tie onto the structure of your existing building and so planning is extremely important to get it right. Without sufficient planning you run the risk of causing damage to the structure of your house. It's essential that you put plenty of effort into planning so tat you can ensure the safety of your building.
Step 1 - Considering the Type of Roof
You first need to give some thought to the type of roof that you are using for your porch roof addition. There are several different types of roofs which are suitable for porches, these include pitched roofs and flat roofs. Decide on the type of roof before doing anything else because this will affect the cost of the project and also the types of materials you will need to order.
Measure the dimensions of the roof so you know exactly what's required and the types of materials which you will need to purchase.
Step 2 - Working out the Supplies
Once you know the design that you are building it should be fairly easy to work out the supplies you need. To do this sketch out the design on a sheet of paper and work out the quantity of everything you will require to successfully complete the entire project. It shouldn't take that long to work this out but you will need to try to be as accurate as possible. Be sure to use the measurements you used and give yourself extra materials for mistakes.
Step 3 - Estimating the Cost
Once you know the list of supplies, it becomes easy to estimate the cost of the addition. Take a look at the list of supplies and find out how much they will cost. Also remember to include any labor or additional tools that you might need to purchase to complete this project. This way the estimate will be as accurate as possible. Be sure to estimate accurately and add an additional 20% cost for incidentals. This a critical step in the process because you want to be certain you can afford the project.
Step 4 - Getting the Plans Signed Off
When you have accurate plans, it's important to take them to an architect to ensure that they are safe and won't cause any damage to your property. Get your plans signed off to make sure that they comply with the current building codes and regulations. This is very important because it will make sure that you don't end up getting fined for not meeting building regulations.
Step 5 - Ordering Supplies
Once you're happy with the design, you will then be able to place your order for the necessary supplies to complete and finish the project. Make sure that you shop around and get the very best deal you possibly can for your roof addition.
