How to Polish Diamond Plate
Learning how to polish a diamond plate requires some knowledge about the surface and the best way to keep it clean. Diamond plate surfaces are made from steel or aluminum and has raised, diamond-shaped treads on the surface. These surfaces are found on a truck’s running board and tool boxes and usually come unfinished.
Materials Needed to Polish a Diamond Plate
To polish the diamond plate surface, begin by hosing the surface off with water.  This is done to remove any debris or dirt that may accumulate. The surface should be permitted to dry before you begin working on it. A phosphoric acid, nylon scrubbing pads and metal polish should be used to polish the diamond plate. These products can be purchased from an auto parts or auto supply store. You want to purchase a lot of nylon scrubbing pads, based on the size of the surface being polished, because you should expect to go through quite a few of them.
Wear Safety Equipment and Apply Compound and Polish
Wear latex gloves and protective eyewear when working with the phosphoric acid compound. Work the compound into the diamond shaped treads until the residue dries.  It will appear white but that is ok because the metal polish will finish off the look. Spray with water and dry with towels before applying the metal polish. Wipe the polish with a soft cloth after application and you are done.
