How to Prevent Ice Storm Damage
Preparing your home for ice storm damage is essential if you get a fair bit of snow in the area you live. Damage from ice and snow usually occurs on the roof of your property. Fortunately, there are various ways to prepare for this without spending a great deal of money. It is very important that you fully prepare the house for the onslaught of the winter storms far in advance. Once bad weather actually hits, there will be little or nothing that you can do to lessen any damage. You should prepare your roof and any trees near the house to prevent ice storm damage.
Tools and Materials Needed:
- Insulation
- Tree branch pruning tools
- Ladder
- Roof weather-guards
- Weather-shields
Step 1 – Insulate Your Roof
You may be thinking that insulating your roof only serves to keep your house warm. However, insulating your roof is also an important preparation for lessening the risk of ice storm damage. This is because the ice and snow that forms on the roof of your house will melt faster if there is more heat in your roof space. The warmer air in your home will rise into the roof space and heat up the roof, which will, in turn, cause the ice to melt. This will help to prevent a very high build up of ice and snow on the roof which can cause damage. In the worst case scenario, the weight of excessive ice and snow can even cause a roof to cave in completely.
Step 2 – Use Weather-Guards
Installing weather-guards on the side of your roof will help to prevent flows of ice and snow from falling over the edge and damaging the gutters and other parts of your house. In places where quite severe ice storms are regularly experienced, it is also important to shield your roof. A weather-shield consists of a type of material which needs to be rolled onto the entirety of the roof, including the eaves and valleys. This will prevent water from getting in through the shingles and causing damage to the structure of your roof.
Step 3 – Prune the Tree Branches
Unstable branches hanging over the roof of your home can cause severe damage if they fall off into the roof. Masses of branches can also hold a great deal of ice and snow in some cases. This can cause damage to the roof as well if it falls off. Trees near your house need to be properly cared for. If you are planting new trees, plant ones which are more suitable for climates where ice storms are common. Make sure that you prune back any loose branches hanging over the roof of your house or over any electrical wires. If there are any trees which are severely damaged, you should cut these down entirely. Making these preparations will help to ensure your home is safer during all sorts of stormy conditions.
