How to Prevent Paint On Ceramic Floor Tile from Bleeding
To prevent the paint from bleeding when you paint ceramic floor tile, you must make careful preparations. Using primer before painting will give the paint something to stick to, alleviating problems with bleeding. Even if your ceramic floor is not in good condition, the primer will help to smooth out areas that may be scratched or dinged, allowing for even coverage. Paint primer will also keep stains from seeping all the way through should something drop on the floor. Paint primer will not only prevent bleeding, but also prevent other problems later on.
