How to Properly Read a Measuring Tape
measuring tape
While a tape measure is often the most simple and handy way to make measurements around the house, it does present some logistical challenges compared to its firmer cousin, the ruler.
Measuring tape is pretty straightforward, but there's no shame in getting a tad disoriented. The following is a quick overview of how to properly read a measuring tape in daily use.
Step 1 - Understand the Markings on the Tape
If your tape is marked with the English or Standard system, it will be broken into inches. Inches are in turn broken into fourths, eighths, and sixteenths. Each decreasing fraction is marked with a shorter line than the previous one, making the distinctions easy to read even if you are not looking at the tape head-on.
Step 2 - Position the Tape
Hold the tape dispenser in a comfortable position relative to your body and extend the tape across the surface you are measuring.
Step 3 - Read the Markers on the Tape
Start with the closest number visible. Then determine on which side of the "half" mark between numbers your measure sits. Count down or up to the nearest fraction.
Make sure to hold the tape steady to get a proper reading!
