How to Put Nails Into Concrete Blocks Under a Wood Floor How to Put Nails Into Concrete Blocks Under a Wood Floor
Concrete nails
Hammer
Power drill
Drill bits
Screwdriver
Protective Eyeglasses
Working gloves
Putting nails into concrete blocks under a wood floor can be quite tricky. Using the wrong nails can cause the concrete to crack or chip so you need to be extra careful when it comes to the kind of nails that you use. To help you put nails into concrete blocks under a wood floor, here is what you need to do.
Step 1 – Observe Safety
Before you start hammering nails into your floor, you need to wear your protective eyeglasses and working gloves first.
Step 2 – Drill Holes into the Concrete
Drill small holes into the concrete and on the wood to accommodate concrete nails. Make sure that the holes must be smaller than the size of your nails.
Step 3 – Insert the Anchors
Insert the metal anchors into the holes and push the anchors all the way through the holes using a screwdriver. Make sure that the anchors are securely lodged into the concrete floor before you insert the nails.
Step 4 – Put in the Nails
Put the wood over your concrete floor and align the holes on the wood with the holes on the concrete. With the use of a hammer, push the concrete nails through the holes on the wood and make sure that the nails go all the way down to the anchors.
