How to Remove Adhesive From Ceramic Tile
A simple pattern made from ceramic tile on a floor.
  • 1-2 hours
  • 0-50
Nail polish remover
Cloths
Lighter fluid
Paint thinner
Mineral spirits
Protective gloves
Razor blade
Nail polish remover
Cloths
Lighter fluid
Paint thinner
Mineral spirits
Protective gloves
Razor blade
If decorative work is being carried out near ceramic tiles, it can be incredibly easy to splash small spots or spill an entire pot of glue over them. Spillage needs to be cleaned up quickly but doing so is relatively simple and only requires a small amount of effort.
Step 1 - Clean the Small Spots
If there’s just a small spot of glue on the tile, you can use nail polish remover to remove it. Put some of the liquid on a cloth and rub the spot. It will soften the glue and afterwards you should be able to remove it by applying pressure with your thumbnail under the edge of the glue.
When you’ve finished, clean the tile with soap and water to remove any last traces.
Step 2 - Clean Up Larger Areas
natural colored ceramic tile floor
Where you have a larger area of glue, you will need to soak a cloth with something that will soften the glue. Lighter fluid, paint thinner, and mineral spirits will all do the job, but don’t mix them together or use them with bare hands. Lay the cloth over the glue and leave for 15 minutes. This will allow ample time for the liquid to work the adhesive.
Remove the cloth and take your razor blade to it. You should either use a single-sided razor blade or a double-sided blade with a holder covering one of the sides. Start scraping the glue off, always working away from you for maximum safety.
Clean the blade often as you work and you should be able to remove most of the glue this way. Soak the cloth again and reapply, leaving it again for a short while before scraping again.
Repeat the process several times until you’ve been able to scrape off all of the glue. This process will actually work on most types of adhesive, so keep it in mind for any other spills as well.
Use soap, water, and a clean cloth to clean the entire area that was covered by glue to take away all the last traces of stickiness. If you don’t, dust and lint will stick and the tiles will look ugly in no time at all. When you’re using these liquids with a cloth, keep them away from flames and don’t smoke in the same room as they are very flammable.
Step 3 - Remove Super Glue
tube of super glue
When people are working with super glue, drops sometimes spill by accident. Because of the high strength levels of super glue, you will use a slightly different method of removal. Unless it’s a large area, you should be able to take it all off with just a razor blade once the glue is dry.
Step 4 - Additional Tips
Make sure your cloth is completely soaked in your liquid of choice, as this will help it soak into the glue fully. Don’t try to rush; instead, scrape gently. Luckily, the hard finish on ceramic tiles means that the razor blade won’t scratch them, but you should still take care.
Also, you’ll want to have several razor blades on hand to start using a new one as soon as the old one becomes blunt.
Remove Adhesive From Ceramic Tile FAQ
What is the easiest way to remove tile adhesive?
The easiest way to remove adhesive is to warm it up first with a hair dryer on a low setting. This will soften the glue and make it easier to scrape away with a putty knife.
The softened glue is also easier to remove with chemical agents designed to loosen adhesive.
Does acetone damage ceramic?
Acetone is a common household chemical that is found in many nail polish remover formulas. It is highly abrasive and can damage some types of stone, including marle.
However, acetone does not damage ceramic. And since acetone can also dissolve glue residue, you may want to try this chemical on ceramic to see if this can treat and remove the adhesive.
Will adhesive come off tiles?
Adhesives are difficult to remove, especially after they have died and hardened on tiles. However, it is possible to remove adhesive completely from tiles, even if you have to use a razor blade to carefully scrape the adhesive off the tile painstakingly.
Does vinegar dissolve ceramic?
Vinegar can be used on ceramic tile but the natural acids in vinegar make it highly corrosive. Dilute vinegar with water, because fully concentrated vinegar may cause damage to tile.
What does baking soda do to ceramic?
Baking soda is used as an all-purpose cleaner around the house on multiple surfaces but it is mildly abrasive. Baking soda can cause scratches and damage to ceramic surfaces, like tile.
