How to Remove Grout Sealer From Tile
grout
  • 0-40
Scrubbing pads
Vinegar
Water
Bucket
A putty knife
Scrubbing pads
Vinegar
Water
Bucket
A putty knife
You are bound to get a little grout sealer on your tile while you are sealing the grout. If this happens, do not be alarmed because there are a few quick things you can do to clean the grout and prevent haze from getting onto the tile surface. Below you will find a short instructional on cleaning up the grout sealer from the tile.
Step 1 - Clean With Warm Water
Take out a small bucket and fill it with a little warm water. Using a scrubbing cloth or sponge, clean the sealer. This works great for areas that you may be sealed by accident and noticed it right away. Check back in an hour to see if it has been removed completely.
Step 2 - Use Vinegar and Water
Mix a light solution of vinegar and water (50% vinegar and 50% water) into another bucket. Clean again with a scrubbing pad.
