How to Remove Rust from Steel Kitchen Work Tables
Rust remover
Cleaning rags
Bucket or a container big enough for your steel equipment to fit into
Potable drinking water
Rust on kitchen work tables can be very unappealing. But most people just ignore them not knowing the damages it can cause to their stainless house machines or obstruct your tools from functioning properly. Rust can be a common problem especially to those who owns too much steel material at home and also to those who has workshops in their cellars. Rust can destroy your belongings easily.
Once you have noticed rust on your steel kitchen work table, do something about it right away before it gets worst. By reading the article below, you will be able to learn helpful steps on how to remove rust effortlessly on your steel tables. These steps also work for kitchen work tables with carvings, gaps and rough surfaces. The steps provided below takes on a small effort to accomplish without affecting your surroundings or the environment.
Step 1- Purchase the Right Tools
Buy any rust remover products. When purchasing rust remover product, choose the brand that comprises chelation agents. This product does not cause harm to the environment, therefore it is very safe to use.
Step 2 – Rub It with the Rust Remover
Using a slightly rough cloth, rub or scrape any rust or dirt from the steel table surface. Do not worry; the rust remover will not harm wood or plastic parts of the steel. However, it can remove paints and bluing.
Step 3 – Prepare the Solution
Next, put the steel or tool into a bucket filled with rust remover. Make sure to use a plastic container to avoid any type of chemical reactions.
Step 4 – Soak Your Tools
Fill the table with the solution and let it stand there for thirty minutes. You can let it stand for ten more minutes if there is stubborn rust. Use warm water in your solution because it is more effective this way.
Step 5 – Rinse the Table
After thirty to forty minutes, rinse the table with portable drinking water. Make sure that you wash it thoroughly leaving no trace of the solution. To completely get rid of rust particles, use a clean rag or cloth to wipe out the rust that was not removed
Step 6 – Repeat the Process
If there are still rust particles left, you can perform the same procedure. It is normal for extremely rusted steels to undergo another application
Step 7 – Store the Solution in a Safe Place
Once the procedure is accomplished, do not dispose the used solution as you can still use it for your other decomposing steel tools. Put the product in a safe place so that you know where to find it for future usage. Like other liquid products, make sure to seal the bottle as it can evaporate.
