How to Remove Stains from Saltillo Tiles
Empty spray bottle
Ammonia
Sponge
Washcloth
Soft-bristled scrub brush
Water
If your home features any saltillo tiles that have recently incurred any stubborn stains, you'll be pleased to know that they can be cleaned in just a few easy steps. Below is the best way to get your saltillo tiles stain free.
Step 1 - Remove Dust from Your Tiles
Begin the stain removal process by using a damp sponge, washcloth or paper towel to wipe down the affected area and effectively remove any dust or debris. Take care to be as thorough as possible, as any remaining bits of filth may present problems later on in the process.
Step 2 - Apply Your Ammonia-Based Cleaning Solution
You'll now need to produce a mixture of 1 cup ammonia and 2 to 3 cups of water inside of an empty spray bottle. Next, spray your homemade cleaner onto the stained areas of your saltillo tiles and allow it to sit for several minutes.
Step 3 - Remove the Stains
Now that you've applied your homemade cleaner, you're ready to remove the stains that are plaguing your tiles. Using a sponge or washcloth, proceed to vigorously scrub the stains until they have been successfully purged. If the stains prove unyielding, try using a soft-bristled scrub brush.
