How to Remove TV Bases for Television Wall Mounts
Many high definition televisions require you to remove their bases before connecting them to television wall mounts. While the mounting process can often prove tricky, removing the base of your high definition television is a very simple procedure that can be completed with nothing more than a screwdriver. So if you've been looking for a way to remove your HD television's base, simply read on to learn everything you'll need to know to complete the job in a timely and stress-free fashion.
Tools You'll Need
  • Screwdriver
Step 1 - Take the Necessary Safety Precautions
Before you can remove the base of your high definition television and connect it to a television wall mount, you must first make sure that the device is turned off and safely unplugged. In addition, make sure that any cables belonging to devices connected to the television have been properly disconnected. Given the large number of devices to which most modern day televisions are connected, make sure to double check that all cables have been removed before proceeding any further. Keep in mind that when working with electronics, safety should be at the top of your priority list.
Step 2 - Carefully Lay Down Your Television
Now that you've taken the preparatory safety precautions and made all the preliminary disconnections, carefully pick up your high definition television and gently lay it on a soft, flat surface, making sure that the screen is facing upward. If you own a particularly large HD television, you may want to incorporate the aid of a friend or family member to assist you with the lifting. The best kind of surface for this job is a clean towel that has been placed on top of either a perfectly flat table or a wood floor. Carpets, while soft, may give way to static electricity discharges, thus potentially shortening the life of your high definition television. Additionally, the surface of a typical carpeted area may not be flat enough to suit your purposes. Remember, high definition televisions are modern day marvels, but they are also extremely fragile. Once you've laid your television atop a suitable surface, you'll be ready to move on to the final step.
Step 3 - Disconnect Your Television's Base
Having set your high definition television down on a soft, flat surface, you're now ready to detach the television's base, thus prepping it for a television wall mount. This is arguably the simplest part of the process. Take out your screwdriver and carefully unfasten the screws that bind your television's base to the device's back end. Once you've disconnected the screws, use your hands to gently slide the base out of place and your high definition television will be ready to be connected to a television wall mount.
So there you have it. With the aid of this easy-to-follow guide and a simple household screwdriver, your HDTV can be prepped for a television wall mount in no time.
