How to Repair a Boat Bench Seat
  • 2-8 hours
  • 50-200
Scissors
Pen
Fabric
Staples
Stapler
Fabric adhesive
Foam
Utility knife
Tape measure
Saw
Pressure-treated wood
Hammer
Galvanized nails
Small pry bar
The most common issue with a boat bench seat is the fabric covering the cushions becoming worn due to saltwater. The wood of the boat bench seat can also rot and warp. The article below will explain how to repair a damaged boat bench seat with this problem.
Step 1 – Worn Fabric
Remove the cushion from the boat bench seat, and turn it over. Remove the current fabric. Place the new materials on a flat surface, and then place the current fabric on top of it. Trace it, and then cut it out. Place the foam in the center, and wrap the fabric around it, stapling it in place.
Step 2 – Worn Padding
If the foam padding is damaged use the old padding as a template for the new. Trace it and then cut it using the utility knife. Depending on thickness, this could take several passes. Replace the fabric as in Step 1.
Step 3 – Bad Wood
Pry off the damaged wood, and then measure the pieces. Transfer the measurements to the new wood, and then trim them. Place the fresh wood, and nail in place along the edges.
