How to Repair a Brake Rotor How to Repair a Brake Rotor
Owner Manual for Car
New Set of Brake Rotors
File
Socket wrench and sockets
Are you familiar with what you will need to do to repair a brake rotor? Brake rotors, depending on their condition, should be refinished or replaced when the brakes are realigned. They absorb much of the heat created by the friction of the brake pads against them during braking. Things like stress cracks, deeply pitted areas from rust, getting out of round (run out), deep grooves in the surface or being worn down to minimum specifications or the discard thickness are indicators that it is time to replace the brake rotors. Before replacing the rotors, you can repair them by filing them down (to reduce the un-even spots) or taking them to a mechanic to 'true up' or re-shape appropriately. Here is what you need to do to repair the brake rotors, in an effort to save some money on the replacement.
Step 1 - Check Manufacturer Specifications
Pull out your automotive manuals and read through all of the manufacturers specifications and recommendations. After reading through the information, if you are not comfortable with what is required for the repair, then you are best to take your car to a qualified repair technician.
Step 2 - Test Drive Your Car
Before you begin to repair your brake rotor, take your vehicle for a light drive on a highway or freeway. Once you are up to a good speed, and making sure there are no other cars around you, apply a light constant pressure to your brakes. You need to see whether or not you are getting any vibration when you apply the brakes. If you are feeling strong vibrations, you will need a professional to re-machine the rotors. If there are very mild vibrations, then you can file down your rotors to repair them yourself by following the directions below.
Step 2 - Jack Car Up
Begin by lifting the car up in the air. Using a set of car ramps or a jack, put the car up so that you can easily walk around the car and get to the wheels.
Step 3 - Remove the Wheel
Pull off the lug nuts and remove the wheel of the car
Step 4 -  Pull off the Brake Pads
Remove the brake pads carefully to expose the rotor.
Step 5 -  Pull off the Rotor
Using the right amount of torque, remove the lug nuts that hold the rotor in place.You will need the right socket to take the rotors off properly
Step 6 -  File the Rotor
Using a small file, intended to file down a brake rotor, gently file the surface until you get an even and smooth surface. Do not try to over file.
Step 7 -Re-Assemble
Reassemble your braking system for that wheel. Put the rotor back on first, tighten into place. Add a little lubricant. Put your brake pads back on second and then add the wheel back on. Make sure everything is tight. Proceed to each wheel, as required.
Step 8 - Test Drive
Take you car out for a test drive on local roads first. Then venture onto highway or freeways.
Tips:
If filing your rotors does not do the trick, take them into your mechanic and have the mechanic use what is called a rotor truing machine to take care of the major warps and cracks. The machine will reshape the rotor so that it can be used again.
