How to Repair a Broken Pick Axe
Hand-held sledge hammer
Drill with diamond parts
Linseed lubricating oil
Small painting brush or cleaning cloths
Steel wedges
Despite the fact that getting a pick axe crack as a result of ruin to the head of the axe is uncommon, it can occasionally happen. In such situations, you could possibly preserve your handle and attach a replacement axe head on the handle. Nevertheless, axe heads are supposed to remain attached under the most difficult conditions, and frequently the axe handle will break prior to the axe head itself coming loose or flying out. Detaching the head and preserving the pick axe handle is often a tough task, and it might turn out to be both less complicated and cheaper to throw away the damaged axe. Nonetheless, if you want to repair a broken pick axe, here's how.
Step 1 – Pull out the Pick Axe Head
Take out the broken pick axe head by holding the handle and pulling it out, presuming it had not dropped down previously. This tends to prove to be the most challenging part of the work. Begin by utilizing a hand sledge hammer to hit the axe head on the flat sections of the lower part. In case that will not work, your best option is to release the axe grip on the handle of the damaged axe top by drilling a number of grooves in the iron surrounding the eye of the axe. This will probably eat out your steel drill parts that are more costly than a substitute axe handle, unless you have a drill with diamond parts.
Step 2 – Check Your Axe for Extensive Damage
Look at the top part of the pick axe handle after removing the head. If it is badly split or decaying, it should not be utilized and you will have to begin again by buying both a new handle and an axe head.
Step 3 – Remove the Steel Wedges
Take out the present steel wedges from the end of the axe handle by using a set of pliers. When the head of the axe has been pulled out, taking out the steel wedges should be an easy job.
Step 4 – Apply Oil
Protect the top part of the axe handle by applying linseed lubricant, making use of either a compact painting brush or an old cloth.
Step 5 – Drive in More Steel Wedges
Position the head of the axe on the handle. Put a new steel wedge on the timber of the eye of the axe, and strike it in using your sledge hammer or a different type of hammer. In case that will not secure the axe head tightly against the handle, strike in another wedge and maybe more wedges.
Considering the effort and cost that might be included in drilling the axe head free from its handle, you may want to seriously consider simply throwing away the axe instead of attempting to preserve the handle and change the broken head.
