How to Repair a Casement Window Latch
  • 1-2 hours
  • 10-50
Household oil (as needed)
Small wire brush (as needed)
Cloth or rag
New fastener set (as needed)
Screwdriver
Casement windows latches are part of the mechanisms built in with a casement window. A casement window is a window sash attached by hinges on a frame to allow it to open. It is opened by the use of a crank or by hand. It is a simple process to repair a latch—the metal clasp which pivots and slides into a stationary metal fitting, creating a lock to keep the window closed. One side will be affixed to the inside window frame and one side will be affixed to the window sash. There are different configurations of latching mechanisms, some close on the side of the window and some on the bottom of the window. These clasps can become rusted, break with age or begin sticking due to dirt or grime.
Step 1 – Determine the Problem
You first need to determine the problem with the latch. If it is broken, you will need to replace it completely rather than try to repair it. If it is stuck or dirty, you can clean it. If it is rusted, you can also try to clean it. Depending upon the severity, this fix may not work and you may have to replace the latch.
Step 2 – Clean the Latch
Begin by inspecting the latch to see if there are any visible obstructions keeping it from working. Spray a small about of oil into the mechanism, keeping a rag handy for any overspray or drips. Try to move the clasp back and forth and see if loosens up the movement. Repeat this procedure a few times. With a little bit of work, you may have just fixed your problem.
If there is a rust problem, use a small wire brush with some oil to gently scrape at the rust. If there is only a small amount, you may be able to remove it and use the clasp again. Again, move the clasp back and forth and try to loosen it up. You can also try using a rust removing solvent. You will need to oil it or apply petroleum jelly after using a solvent.
Step 3 – Replace the Fastener
If your latch is broken or rusted beyond repair, you need to replace it with a new one. It is best to buy one with the same size and shape. Remove the old clasp by removing the screws and simply screw in the new clasp in the same place that the old one came out.
