How to Repair a Leaking Roof Valley: Closed-Cut Valley How to Repair a Leaking Roof Valley: Closed-Cut Valley
Pry bar
Hammer
Roofing nails
New panels, tiles or slabs
To Repair Leaking Roof can be a headache for you. Leakage in a roof valley usually occurs due to weathered panels, pan tiles or flashing which are not working properly. In any of the cases, you will have to replace some of the panels, pan tiles or slabs to mend the leak. Before starting to replace the withered material you will have to analyze the panels or tiles properly. Approximately calculate the material which is required for the replacement. Follow the detailed instructions below in order to determine how to repair a leaking roof valley.
Step 1 – Necessary Measures to be Taken
When repairing the roof from leakage, you may also use the tiles or panels which are exactly the same as your previous panels or tiles. You should always chose thick, good quality tiles and panels. The pry bar should be used very smoothly; if you apply too much pressure with the pry bar, you may break additional panels or even the roof. This will end up in you having to make additional repairs. Proper placement of nails is extremely important so do not put the nails on the junction area. Make sure the nails are not too close to the roof valley since they may cause strain on the panels or tiles and hence they may break more easily. If you live in a locality which is subject to stormy weather, then you should try not to use cement or roof pitch. Sometimes heavy rains or storms may blow away your tiles. To avoid this, you should use nails to hold the panels or tiles in their place.
Step 2 – Taking off the Withered Panels or Tiles
Now pull the withered panels that easily come off the roof. If the other panels are surrounded by some withered panels, then you need to pull off the withered panels by uplifting the edges of the other panels or tiles. If the tiles or panels are fixed with the help of nails, you may use a pry bar to pop out the nails.  Pull off all the worn out panels or tiles easily.
 Step 3 – Placing the Flashing
Now place the metal flashing in its place and bend the edge of the flashing in a way so that it forms a corral which is about 1 inch wide. The purpose of creating a corral is to ensure the flow of water, and the enclosure shape of the corral will enable water to easily flow down to the drain.
Step 4 – Finishing Up
Now, adjust the new panels in the valley area in such a way that they should be placed in the same direction as the already placed panels. The edges of the new panels may overlap the older ones, and for correcting that, just lift up the edges and insert 2 roofing nails on each top corner of all the new panels. Next, insert the nails with the help of a hammer. To finish your work, just adjust the overlapped panels into their respective places on the top of the new panels.
