How to Repair a Plastic Screen
Ready made patches (or newly cut patches)
Long-nose pliers
Household cement
Pliers
A small cutting knife
A window or door screen can easily get damaged, especially if you have pets or children in the house that are constantly running into it. Although you can give it to a professional to repair, in reality,  it is quite easy to repair or replace it yourself. Most probably, even the tools necessary to complete such a task can be easily found in our homes. Repairing a plastic screen may not require special professional skills, but basic craft knowledge or some experience with the material would be beneficial.
Step 1: Checking Overall Damage Caused
The first step to take is to check the extent of the damaged caused and to decide which parts need salvaging and which need to be replaced with new material. Remember that plastic screen material does not cost much. Therefore, do not be reluctant to replace unusable areas with new parts.
Step 2: Measuring the Holes
If there is a hole larger than 3 inches in diameter, then you should replace the whole screen, otherwise it won’t hold properly by patching it.
Step 3: Ready Made Patches or Make Your Own
Once you have measured the holes, then you can buy some ready made patches. If you don’t want to purchase ready made patches, then all you have to do it to cut some patches from a similar or new plastic screen. Make sure to cut each patch at least ½ inch larger in diameter than the original hole or to a maximum of 1 inch larger in diameter than the hole.
Step 4: Attaching the New Patches
Try to unravel the strands near the hole and then weave the strands and twist them tightly. Normally, this can be done with your fingers, but alternatively, you can use a pair of long-nose pliers. Remember that since we are repairing a plastic screen, after the weaving, place a touch of cement (household not heavy duty cement) and put it at the ends of the strands so that it will remain secure. Don’t worry about the look of the household cement, which, at this point, will look more like glue than cement because when it dries it will become invisible.
Step 5: Inspecting
After the cement has dried, inspect the repaired area and make sure that it has been mended properly. In the case that it needs more attention, repeat the same process mentioned above. Once ready, all you have to do is to attach it to it’s proper place.
As you can see it’s not so difficult to repair a plastic door or window screen. The important thing is to work patiently to avoid causing more damage than what is already present.
