How to Repair a Toilet Seal
Wrench
Screwdriver
Rubber gloves
Caulk/plumbers putty
Putty knife or utility knife
New, wax ring rubber seal
New toilet base plastic caps
If you are wondering how to repair a toilet seal, you don’t need to be apprehensive since this is a simple repair job that can be easily done with some basic household supplies. Broken or loose toilet seals are among the most common causes of a leaky toilet. The toilet seal in most contemporary toilets is a ring-shaped seal that has an adjustable collar for tighter installation. This seal is needed for preventing the leakage of water and sewer gases that can pollute the bathroom space. You can use the following guidelines for repairing your toilet seal in an affordable and undemanding manner.
Step 1—Getting Started
Get started by preparing yourself with a pair of rubber gloves. Turn-off the shut-off valve or the main valve that controls the water supply of the toilet. This valve is usually located in the wall upon which the cistern of the toilet is secured. Flush the toilet repeatedly to ensure that any remaining water is also drained-away. Now, proceed towards the base of the toilet, i.e. where the toilet is secured upon the bathroom floor.
Use a flat-headed screwdriver to edge-out the ring of putty or caulk. This can be tedious since the toilet base is tightly packed at the time of installing the toilet. Use the tip of a screwdriver to open the plastic caps present on each side of the toilet’s base. Below the caps, you will find metal bolts that secure the toilet bowl upon the floor. Loosen these bolts with a wrench and remove them.
Step 2—Disassembling Toilet Flange
It is better to seek the help of another person at this time for holding and lifting the toilet bowl. Some times, the toilet bowl isn't properly secured over its base and loosening the flange might cause it to suddenly fall-off. Spread some old rags around the toilet’s base before attempting to tilt the toilet bowl. Ask your helper to slowly tilt the toilet bowl. This might also cause a small splurge of any water that was retained with the exit hole of the toilet along with traces of grime that 's what the rags are for. This should reveal the flange bolt with the accompanying nuts. The flange is a durable fitting, needed for securing the toilet bowl onto the underlying drain hole. Flanges are of different materials, including cast iron, and plastic. Metal flanges are difficult-to-handle since they can be corroded. Use sharp end of a screwdriver to scrape away the rust. Use a wrench to loosen the nut and remove the bolt.
Step 3—Replacing Toilet Seal
It is better not to remove the toilet bowl, as re-adjusting it might become difficult. Ask you associate to keep the toilet bowl tilted as you quickly proceed with the repair. Using a putty knife, edge-out the old wax ring. Replace it with the new wax ring. The wax ring seal should fit tightly. New wax rings tend to protrude a bit, which could impair the tight fitting. Thus, repeatedly press down upon the seal. Now proceed towards inserting the flange bolts. Use a wrench for tightening the bolts.
Step 4—Wrapping-up Toilet Seal Repair
Ask your associate to gently position the toilet bowl in its original position. Doing this with a jerk can crack the underlying ceramic tiles of bathroom floor. Insert the metal bolts to secure the toilet bowl upon the floor and tighten them with a wrench. Replace the plastic caps you had removed at the start of the project. Finally, apply a thin bead of caulk around the base of the toilet for a tighter fitting.
