How to Repair an Exhaust Fan Motor
  • 0.5-1
  • 10-20
Screwdriver
Putty knife
Screwdriver
Putty knife
An exhaust fan motor is something that you are going to have to keep up with. You will find that mold and mildew can begin to build up if the exhaust fan is not properly running in your bathroom. You will need to make sure that the design that you room is able to allow for the steam to go up into the fan. The repair on an exhaust fan motor is something that can be a hassle but it is something that you will need to do. Mold and mildew can be dangerous and has a distinct odor that can also create allergies.
Materials Needed:
Screwdriver
Putty knife
Step 1 – Prepare
The first thing that you will need to do is get the electricity cut off in the bathroom. This is something that needs to be done before you even begin work on the fan. Even if you are not planning on working on the motor right away, you will need to still make sure that the electricity is completely turned off before you do anything with your exhaust fan.
Step 2 – Remove Cover
Once you have the power turned off, you will need to get the cover remove. In order to do this, you will need to unscrew each of the screws with your screwdriver. Make sure that you set the screws aside and do not lose them. If the cover that you are removing has been painted over then you are going to need to get it loosened with a putty knife. You can also use your screwdriver for this as well. It is important that you are careful whenever you take the cover off to make sure that you do not pull off the sheetrock as you go.
Step 3 – Inspect Fan
You will need to take a good look at your fan before you decide what is wrong with it. Look for things such as loose wires that may to just need to be reconnected. You should also keep an eye out for any excessive dirt and debris that could cause the fan motor to stop working.
Step 4 – Pull out Exhaust Fan
You are now ready to pull out your exhaust fan. Make sure that you unplug it first. You should only do this if you could not find anything wrong with the actual fan. You will be able to get the exhaust fan out by applying a little bit of pressure. You will need to be completely sure that all of the screws have been loosened before you attempt to remove the exhaust fan. Make sure the bulb that is in the fan housing has been turned off for a while and is cool before you try to unscrew it.
Step 5 – Replace Motor
You may need to take out the motor and bring it to your local hardware store to get a replacement. Make sure that you take it with you so that you are able to get the right model and size.
An exhaust fan motor is something that you are going to have to keep up with. You will find that mold and mildew can begin to build up if the exhaust fan is not properly running in your bathroom. You will need to make sure that the design of your room is able to allow for the steam to go up into the fan. The repair on an exhaust fan motor is something that can be a hassle but it is something that you will need to do. Mold and mildew can be dangerous and has a distinct odor that can also create allergies.
Step 1 – Prepare
Once you have the power turned off, you will need to get the cover removed. In order to do this, you will need to unscrew each of the screws with your screwdriver. Make sure that you set the screws aside and do not lose them. If the cover that you are removing has been painted over then you are going to need to get it loosened with a putty knife. You can also use your screwdriver for this as well. It is important that you are careful whenever you take the cover off to make sure that you do not pull off the sheetrock as you go.
You will need to take a good look at your fan before you decide what is wrong with it. Look for things such as loose wires that may simply need to be reconnected. You should also keep an eye out for any excessive dirt and debris that could cause the fan motor to stop working.
