How to Repair Cracks in Laminate Slate Flooring
Vacuum cleaner
Detergent or vinegar
Water
Mop
Wax crayon
220 grit sandpaper
Laminate floor repair putty
Plastic scraper
Putty knife
Sponges
Pieces of cloth
Razor blade
Laminate slate flooring is made of sturdy synthetic material that has an elegant appearance and is easy to maintain. However, scratches and cracks may appear on the surface of the flooring, and these can be fixed using repair putty or wax crayons.
Step 1—Clean the Floor
Remove the dirt and dust from the laminate slate flooring using a vacuum cleaner or a broom. Mop the flooring with a solution that contains 1 cup of dish detergent and 3 gallons of water. Alternatively, use half a cup of vinegar in 3 gallons of water. Rinse the floor and wait for it to dry.
Step 2 – Identify the Cracks
Check your laminate slate flooring and identify all cracks and chips. Even the superficial chips should be repaired to prevent additional damage. Mark the areas that need repair. Establish what color of putty you need to purchase. Certain scratches may not need putty and may be repaired with a special wax crayon. Make sure the crayon has a shade that is similar to the color of the flooring.
Step 3 – Sand the Area
Sand the inside of the cracks to make the area smoother and remove any dirt that has accumulated. This will make sure the putty will bond well with the flooring. Remove the dust with a moist sponge.
Step 4  Prepare the Putty
Purchase the putty from a hardware store. Make sure that the color you choose is similar to your flooring. Use the available swatch books to find a color that is closest to your laminate slate flooring. Prepare the putty by mixing it with the hardener that is provided in the kit you buy. Use a plastic scraper or a putty knife when mixing, and make sure the putty is homogenously mixed with the hardener.
Step 5 – Apply the Putty
The putty hardens quickly, so you only have a few minutes to apply it. Fill the cracks in your laminate flooring using a putty knife. If your cracks are smaller, use a smaller putty knife, which will allow you to control the amount of putty you apply and avoid putting an excess of filler. Apply several thin layers of filler rather than a large amount of putty at once.
Step 6 – Remove Excess Putty
Remove the excess of putty by employing a damp piece of cloth, but do this before the putty hardens. If the putty is already dry, remove the excess with a putty knife or a razor blade. Use the razor blade with caution to avoid scratching the laminate surface.
Step 7 – Allow to Dry
The putty hardens within minutes, but allow two to three hours for the filler to dry completely before you step on the repaired floor.
