How to Repair Leaking Faucet Fixtures How to Repair Leaking Faucet Fixtures
Pliers
Teflon Pipe Tape
Faucet fixtures that are leaking could end up causing a lot of issues for your home. You will find that your water bill will sky rocket and you may eventually have some issues with mold or mildew. Make sure that you know what to do whenever you notice that the faucet fixtures in your home area leaking. This will allow you to be able to get it fixed as soon as possible before there are any other problems. The longer you wait to fix the problem, the more issues you could end up having over time. A leaking faucet fixture could be trying to tell you of a more serious problem that you are going to have to fix right away.
Materials Needed:
Pliers
Teflon Pipe Tape
Step 1 – Prepare
The first thing that you are going to need to do is get the water turned off to the area that you are going to be working on. For instance, if it is for your sink, simply go underneath it and turn off the valves. You can also turn off the main supply of water if you cannot find the fixture that is under the sink. This is something that you may also need to do if it is for your shower or for a place that the valve underneath the sink is not an option. Make sure that you do this before you continue on with anything else.
Step 2 – Unscrew
Once you have the water turned off, it is a good idea to open up the faucets throughout. If you have turned off the entire water supply, then do this with all of the faucets. However, if you just did it for one location, then open up just those faucets and allow them to empty out. Once you have done that, you will need to get the shower fixture unscrewed from the pipe in the area where it is leaking.
Step 3 – Thread Tape
Once you have the shower fixture unscrewed from your pipe, you will need to get your pipe thread tape and wrap it completely around the threads of your pipe. You should do this at least 2 to 3 times. Make sure that all of the threads are completely covered before you move on to the next step. Do not put too much thread tape on the pipes as this could cause an issue with putting them back.
Step 4 – Tighten
Once you have the tape on, you will need to get the fixture tightened back onto the pipe. It is important that you do not get it as tight as you can get it. This is something that could end up doing a lot more damage than what is already there. Tightening the pipes too much could end up causing too much pressure. Make sure that they are tight enough where they will not leak. Once you have tightened them, turn the water on and make sure that there are no leaks. If there are, then you may need to either tighten them more or apply more tape.
Faucet fixtures that are leaking could end up causing a lot of issues for your home. You will find that your water bill will sky rocket and you may eventually have some issues with mold or mildew. Make sure that you know what to do whenever you notice that the faucet fixtures in your home are leaking. This will allow you to be able to get it fixed as soon as possible before there are any other problems. The longer you wait to fix the problem, the more issues you could end up having over time. A leaking faucet fixture could be trying to tell you about a more serious problem that you are going to have to fix right away.
Step 1 – Prepare
Step 2 – Unscrew
Once you have the water turned off, it is a good idea to open up the faucets throughout. If you have turned off the entire water supply, then do this with all of the faucets. However, if you just did it for one location, then open up just those faucets and allow them to empty out. Once you have done that, you will need to get the fixture unscrewed from the pipe in the area where it is leaking.
Once you have the fixture unscrewed from your pipe, you will need to get your pipe thread tape and wrap it completely around the threads of your pipe. You should do this at least 2 to 3 times. Make sure that all of the threads are completely covered before you move on to the next step. Do not put too much thread tape on the pipes as this could cause an issue with putting them back.
Step 4 – Tighten
