How to Replace a Ceiling Fan Pull
Pull chain lights switch
Screwdriver
pliers
Voltage tester
Wire connectors
Electrical tape
Overtime the ceiling fan pull chain is damaged due to frequent usage and needs to be replaced. Most ceiling fans have accompanying light that turns on and off as you pull the ceiling fan pull chain. The pull chain when tugged lights up the bulb and turns on the fan. However, the frequent tugging of the chains could break and cause the fan and light to malfunction. Below are the materials that you need along with the instructions on how to replace a ceiling fan pull.
 Step 1-Switching Off Electric Power
Switch off the electric power through the circuit breaker control or directly from the switch in the wall.
Step 2-Bulbs and Glass Covering Removal
Remove the bulbs and the glass covering from the fan’s lighting area. Find three screws attaching the lighting covering to the body of the fan, then take it off.
Step 3-Detach Lighting Assembly
When the three screws are removed, gradually take down the lighting assembly from the body of the fan. Look for the switch of the pull chain controlling the lighting assembly. Test to make sure that the power is turned off using a touch-type voltage tester.
The pull chain assigned to the lights are normally the one situated at the lower part of the fan which is near the lights, while the pull chain assigned to the fan is the one situated near the fan blades.
Step 4-Remove the Pull Chain
Take out any chain dangle from the chain. A screw-on cap can be seen where the pull chain connects to the fan and a chain comes out of it. Take out the screws to get out the cap so that the pull chain may be disengaged from the fan’s body.
Step 5-Pulling out Old Chain Switch
Examine the switch to find two black wires connected to it. Take out the wire connectors from both of the wires connected to the switch. Throw out the old pull chain switch.
Step 6-Attaching New Chain Switch
Connect the new pull chain switch by attaching one of its wires to the black wire that was previously disconnected from the old switch. Attach the other switch wire to the other black wire. Securely attach both wires using wire connectors, and cover it with electrical tape to join the connectors and the wires.
Step 7-Reattach the Chain
Take out the cap of the new switch. Place in the chain and the interlocked nipple through the hole where the old switch was positioned. Put in the cap over the chain and bolt it in the interlocked nipple to securely position the pull chain switch.
Step 8-Installing Back
Insert all wires back in the box and replace back the three screws previously removed. Put back the glass covering shade, bulbs and any chain dangle. Switch back the power and test the newly installed pull chain to ensure that it works right. You have just successfully replaced a ceiling fan pull.
