How to Replace a Rear View Mirror
0.5-3
Beginner
- 2-60
The rear view mirror is a vital part of a car because this is what the driver uses to get a better view of what is going on behind the car when driving. This car accessory is positioned at the windshield area and is secured with a special adhesive. Adhesives such as glue can dry and loosen its hold on the windshield. When the rear view mirror’s grasp on the windshield loosens up, you can either repair or replace your rear view mirror. A rear view mirror repair kit is available at car parts store that contains the materials needed for the repair. Below are the materials that you need along with the instructions on how to replace a rear view mirror.
Step 1-Detaching Wiring Connections
Detach any wiring connections to the rear view mirror. Pull out the tabs from the harness to guarantee that the connector is separated from the harness.
Step 2-Loosening the Mirror
Remove the rear view mirror from its support. Using an Allen wrench, undo the screws. By this point, the rear view mirror will easily come off. A metal button will be seen protruding by the windshield.
Step 3-Marking the Button for the Reinstallation
Mark outside of windshield using a crayon to trace the mark left by the metal button because this will be the spot where the rear view mirror will be reinstalled. If you mark the inside the mark will be removed during the cleaning process.
Step 4-Removing the Metal Button
With the use of a putty knife, the metal button should be scraped off the windshield. This procedure should be done lightly to ensure that the windshield will not get damaged. When all the glue had been removed, this will make the button fall off.
Step 5-Clean Rear View Mirror Area
The area where the rear view mirror is positioned must be wiped clean using alcohol to take out whatever dust or dirt is left. The metal button must also be cleaned with alcohol. Allow the cleaned areas to dry.
Step 6-Applying the Activator Vial
An activator, which is in a vial, needs to be applied to the button. Once the vial is broken, the cotton swab contained in it will get soaked in fluid, which should be applied onto the button.
Step 7-Gluing the Metal Button Back
Place a large drop of glue on the side of the metal button that goes next to windshield. Hold button in position against windshield for a minute to allow it to stick to the windshield. The button placed in its position must be allowed to sit on and dry for about an hour to make sure that it bonds securely with the windshield glass.
Step 8-Attaching Back the Rear View Mirror
Once the button is securely in place, attach the rear view mirror by sliding its back onto the button.
Step 9-Securing the Mirror
Secure the mirror’s position by tightening the screw to the metal button. Any wires that need to be connected should be attached also.
