How to Restore Furniture With Water Damage
Wood that has water marks.
  • 1-12 hours
  • $20-70
Toothpaste
Baking soda
Bleach
Veneer glue
Syringe
Moisturizer
Water damage to furniture as a result of flood or weather is not always as bad as it seems. Often the damage is quite manageable, or at least subject to partial repair. Read on for steps you can take to restore your water-wrecked furniture and carpeting.
Step 1 - Drying Wood Furniture
When a piece of wood furniture has been soaked in water, the very first thing to do is to let it dry. Place it in a room with warm temperature and good air circulation. You may want to turn on the heating and the fans. Alternatively, if the weather permits, you can leave the furniture to dry outside.
Make sure the temperature is right. If it is too cold, the wood piece will dry too slowly and mold will form. If it is too hot, cracks will form in the furniture.
Step 2 - Treat White Spots
If white spots have formed on the furniture, mix a solution of equal parts toothpaste and baking soda. Dip a wet cloth in the solution, and rub it both in and around the spots. Polish the area with a dry piece of cotton fabric. If your furniture has leather padding, use other methods to clean those areas.
Step 3 - Clean Mildew
Black spots on your furniture indicate that water has seeped through the finish into the wood, leading to the formation of mildew. In this case, you will have to remove the finish, clean the mildew with a bleach solution, and coat it with a new layer of finish.
Step 4 - Take Care of Buckled Veneer
The furniture veneer may buckle or warp as a result of contact with water. To repair the damage, you can soak the veneer with a moisturizer until it lies down flat again. Wipe it dry and clean. Fill a syringe with veneer glue and stick the needle between the veneer and the body of the furniture. Empty the syringe slowly. Remove it and place a wood block on top of the veneer. Wait for the glue to dry. Follow the manufacturer’s recommendations for the waiting period and remove the block.
Carpets
You can clean water-damaged carpets in one of two ways, depending on the condition of the water.
Damage From Black Water
When your carpet has been damaged by black water, which is heavily contaminated water containing untreated sewage, it is best to dispose of the carpet right away. If you keep the carpet, you risk having a breeding ground for dangerous bacteria and allergens right in the middle of your household.
Damage From Clean or Unsanitary Water
Damage caused by clean or unsanitary water, which includes water from the dishwasher or the toilet, you can restore your carpet without fears for your own health and that of your family. Simply take the damaged carpet out to dry. Remove and dispose of the padding, which you will have to replace in any event. Place the carpet in an elevated position and let it dry for 12 hours.
If mold has formed, or if you feel the carpet needs to be disinfected, use the services of a cleaning company to finish the restoration process.
Now that you know how to restore furniture with water damage you don't have to worry about replacing it. You can use those savings for more furniture!
