How to Seal an Intake Manifold Leak
Your car’s deteriorating performance, water and oil leaks when idling and excessive noise when starting or parking the car may be the fault of an intake manifold leak. An intake manifold transfers gas to the engine’s burning compartment. Locating a leak can be a tricky process, as it leaves no observable trace. However, to make your job easier, follow these simple steps.
Tools and Materials Needed:
- Carburetor cleaner
- Socket
- Screwdriver
- Flashlight
- Inspection mirror
- Spare rag
- WD-40 lubricant
Step 1: Locate the Leak
Inspect your car’s intake manifold to locate the leak. Start your engine, but be sure to begin the inspection before the car heats up to full the operating point. Otherwise, leaks may seal themselves and become more difficult to pinpoint. Lift your car’s lid to search for cracks in the manifold’s exterior. The engines of cars with different manufacturers and models may vary. Therefore, you may have to remove engine covers and shift hoses in order to get a full view of the manifold’s shell.
Step 2: Apply Chemical to Find the Leak
Quickly spray the carburetor cleaner over the manifold starting from the smallest parts first. After covering a section, focus on the inactive engine to see if it reacts. If there is no reaction, move on to the next part and repeat this process until you locate a spot that reacts to the carburetor cleaner.
Step 3: Preparation
Once you’ve located this spot, it means you have pinpointed the leak. The rest of the process gets even simpler, but first you must prepare to fix this leak at once to prevent future problems in your car’s engine and make the most of its performance. This is vital to ensure the long life of your engine and optimum performance standards.
Step 4: Disconnect the Battery and Fuel Rail
The next step is to disconnect the battery and then take out the air ducts along and the nylon fuel rail. Once you disconnect the fuel rail, you can use your fingers to remove the connector’s wires. You may use a unscrewing tool to assist you in detaching the rings of rubber.
Step 5: Remove the Intake Manifold
Use a socket to retrieve the alternative throttle cables with the cover. Take out the intake manifold and the body of the throttle. Undo both the screws that are attached to the pipe, disconnecting it. Once this is done, you may notice a gasket running down the length of the pipe, which you will use later.
Step 6: Repair the Leak
Now, inspect the intake manifold to find any broken or loose gaskets. If any such gaskets exist, remove them. You may consider replacing these gaskets. Carefully and thoroughly wash your existing gaskets with a high quality lubricant. Fully examine them to make sure there are no particles or debris coated on them. Use a cloth to wipe the gaskets. Next, reinstall every part that you disconnected.
Step 7: Check Your Engine
Now you can check your car to see if it is still showing any symptoms of a leak.
