How to Stain Birch Veneer
Liquid sander
Sander
Sandpaper
Paintbrush
Stain
Mineral spirits
Detergents
Rags
Clear finish
Usually, the birch veneer is used in a situation when hardwood cannot be arranged according to the size of the application. The surface of the insignificant wood is covered with veneer to give it a look of solid hardwood. Being one of the cheapest hardwoods, birch is mostly used to make furniture, cabinets and wood panels. The combination of birch veneer is very commonly used and is economical. Birch wood has a natural beautiful grain that is usually finished in a very light stain. Particularly lighter woods are very difficult to stain. However, proper arrangement can help you reduce such problems.
 Step 1 – Preparing the Veneer for Sanding
First of all, you need to cover the entire surface of the veneer with a layer of liquid sander. You should apply the chemical with a fine bristle brush so that the liquid is evenly spread over the surface. This step is extremely important as it will improve the diffusion of stains by clearing out any oils or other substances on the veneer’s surface. Before sanding, the surface should be left to dry thoroughly.
 Step 2 – Sanding the Veneer
Use a dual-action sander to sand the entire surface of the veneer. This will give you the best results because the dual-action sander gives you a finer finish. With light pressure, move the sander towards the grain. To get the most glossy and softest possible grain, you need to make 3 passes with sandpaper. Hence, first pass with 120-grit paper, second with 150-grit paper and the last pass shall be made using a 180-grit paper.
 Step 3 – Applying the Stain
 Use a very fine bristle paintbrush to apply the stain. Make straight strokes towards the path of the grain and cover the surface lightly overlapping the strokes. If the surface is vertical, you should start from the top, however in case of horizontal surfaces you must start from one end towards the other end. Avoid maintaining consistency or any kind of drips. Any extra stain can be removed with the help of a clear rag. Several coats can be applied as per the requirement however the recommended time for drying of each coat of stain should be followed.
 Step 4 – Sanding the Stained Birch
Thoroughly clean the paintbrush with mineral spirits and then rinse it off using dish detergent and clear water. You now need to sand the stained birch to soften any grain that may have been messed up in the staining process. This will be done using a 220-grit paper. Clear off the surface by blowing to get a dust-free finish.
 Step 5 – Finishing Coats
Do sanding, using a 220-grit paper between all the coats. Apply three clear finish coats. You may use the same brush which you used for the stain. To get better results, use long and straight strokes towards the direction of the grain. To get a smooth and bubbles free finish, avoid redoing sections.
