How to Tell When Your Water Pressure Tank Needs to Be Replaced
Since water pressure tank is an vital feature in your home, it is important to know a little bit about how it works. Read on to learn how to determine whether or not you need to replace it in the near future.
Step 1 - Check Manual
Keeping your manual is an important job as a homeowner or renter. You want to make sure that your appliances are running the way they should as they can be expensive to fix or replace. Check the manual to see how long the water pressure tank that you have typically lasts as well as to see what symptoms to look out for. It is safe to get it checked out or at least look over it yourself around that time to see if everything is in working order or if something needs to be done.
Step 2 - Pressure Decrease
A decrease in pressure is one of the first things that will happen as your water pressure tank begins to go bad and needs to be replaced. The pressure drops slightly, but to a point that you would notice after a few days. Before you actually replace the tank, however, you must make sure that you check to see if there are any leaks or loose connections that could be the actual problem. If not, you may need to make replacements.
