How to Tune a Car Amplifier How to Tune a Car Amplifier
With a car amplifier installed, you have the sound quality that you want. The different settings improve the performance of your radio or CD so that you cam enjoy your favorite singers and bands. The problem is how to best tune your car amp. If you use standard settings, you won’t be able to fully optimize the performance of your car amplifier. To get the most of your amp, here is an easy step-by-step guide you may want to read.
Step 1–Play Music
Choose a recording that you know really well. It is best to pick one with lots of high notes from cymbals, brass and flutes, mid-range notes like vocals, guitar, and piano, and low-range notes like those produced by drums and bass.
Step 2–Look at Components
Examine the components of the car amplifier and their specific functions. There are the high-pass filter, the low-pass filter, and the bass boost. Look for the knobs that correspond to the filters. Before powering up, check if the gain of the amp is set to its minimum.
Step 3–Tune High Pass Filter
Look for a knob or switch with the label “high-pass” on it. Turn it on in order to switch on the filter, or simply adjust the knob to a range of 100 Hz. In this way, you will optimize the higher frequencies that are transmitted through the amp. In general, the high pass filter allows higher frequencies to pass through—usually the main instruments and the vocals. Always test your music to see what works and adjust accordingly.
Step 4–Tune the Low Pass Filter
Locate the “low-pass” knob or switch and adjust the frequency. Similar to the high-pass filter, you may adjust it at around 100 Hz. The low-pass filter, unlike the high-pass, is made for lower frequencies. You may balance the high and low frequencies, restrict or allow more of the frequencies sent to the sub or rear speakers. Just see what works best for you
Step 5–Tune the Bass Boost
Adjust the bass boost if you wish to have low frequency in the sound. The bass boost produces the bass or ‘thumb’ sound effect you hear. The switch for this sound is found on your amp, labeled as “bass boost”. Simply turn it on in order to add additional flavor to your music. It is best if your amp has an adjustable bass boost knob so that you can adjust the intensity of the bass sound according to your taste
Step 6–General Troubleshooting
Fine tuning can be a good way to troubleshoot your car amplifier. Check if the high-pass and low-pass filters perform their functions. Make sure that the physical connections to the amplifier are of good quality. For good amp performance, you need high quality RCA cables, power cables, and speaker wire. You may have all low quality cables replaced with newer and upgraded materials. If you notice any problems due to poor tuning, you should contact technical support for assistance.
