How to Use a Biscuit Jointer
Wood panel
Sand paper
Pencil
Wood cutter
Special glue
Tool box
A biscuit jointer is also known as the plate joiner. All over the world, these biscuit joiners are used  to join 2 panes of wood. Prior to the invention of these biscuit joiners, carpenters used to use glue to stick 2 pieces of wood together or use drill holes to hold them together. The only problem relating to these processes is that the finish is not satisfactory. The best way to ensure that 2 pieces of wood are joined is by using biscuit joiners. These joiners ensure that while gluing or drilling, the wood boards remain still and get joined easily. The process of using these business joiners is simple and easy. One simply needs to refer to the steps given below to use a biscuit joiner.
Step 1 - Thickness and Length
Ensure that both the wood pieces are identical in terms of thickness and length. In order to check this factor, it is advised that you place the wooden boards side by side. Check if the edges are smooth and the thickness of the wooden boards are identical in nature. Be careful to spot any gaps in between. If there are gaps, then either replace the wooden boards or get them closed.
Step 2 - Sandpapering
Use a rough sandpaper to run through the edges. For both the wood pieces to be joined, it is important that the edges are smooth and clear. By running a sand paper through  them to ensure that the edges are even. Ensure that you leave a gap of 3 1/2 to 4 inch from the edge of the board while making the mark.
Step 3 - Pre-Assembly
Place the wooden boards by side on a flat surface. Ensure that the boards touch each others.
Step 4 - Line
Use a pencil to draw a line near the joint. Ensure that this line is a few inches long and broad.
Step 5 - Joining
Double check to ensure that you have placed the wooden boards in the way it is meant to be. A tip to ensure that the boards are being joined in the right manner is to right top on the wooden surface that is meant to face upwards.
Step 6 - Marking
Now, place the biscuit joiner between both the wooden surface. Ensure , that you keep the centre mark of the biscuit joiner  on top of the pencil mark.
Step 7 - Cutting
Once the biscuit joiner is kept flat on the surface of the board, cut that area.
Step 8 - Cleaning
Once the slots are cut, clean the area.
Step 9 - Glue
Put glue on the edges and on the biscuit joiners and let them dry overnight.
Step 10 - Drying Out
Remove any excess glue applied on the woods and ensure that you give them adequate time to  dry out.
Tip: Ensure that you use the best quality wood glue to join the wooden boards together.
