How to Use a Spray Adhesive
Newspaper, cardboard, cloth, plastic for cover
Adhesive remover
Nose mask or face mask
Latex gloves
Wet rags or soft cloth
Adhesive remover
Latex gloves
A spray adhesive is a versatile and handy item that you can use almost anywhere. If applied properly, spray adhesives can result in a seamless and clean item without the fuss and the mess.
Step 1 – Prepare the Work Area
Before you use a spray adhesive, you need to properly set up the area you will use. Choose a well-ventilated area to allow the fumes to circulate properly.
On a table or workbench, place newspapers, cardboard or cloth enough to cover and protect the surface. You can use any kind of material as long as it is big enough to cover the surface. Place the item to be glued on top of the covered surface.
Step 2 – Prepare the Spray Adhesive
Shake the can well before you use the spray adhesive. Never tilt the can upside down. You will notice a dot on top of the can. Use this dot to straighten the nozzle arrow of the can. Check to see if the can is working properly by doing a test spray.
Always wear your nose mask or facial mask when you are using spray adhesive. The mask prevents you from inhaling the fumes while you spray. Also, do not forget to wear your latex gloves, as they ensure the adhesive doesn’t stick to your hands.
Step 3 – Use the Spray Adhesive
For the adhesive to work properly, the surface of the item you want to bond should be clean. It should be clean from any grease, dirt or moisture. You should always hold the spray adhesive upright and should maintain a distance of 6 to 8 inches between the spray and the working space. If you spray too closely, the result might be too wet of a spray, which can result in puddling.
When spraying, ensure you have a uniform coat on the surface of the items to be bonded. You can add a second coat to the surface as long as you work fast to prevent the first coat from drying. To prevent the adhesive from oozing out when you press the pieces together, refrain from spraying the adhesive all the way to the ends of the items.
Step 4 – Observe a Waiting Period
Once you are done spraying the adhesive to the item, wait for 30 seconds before you secure the items to be glued together. This gives the solvent in the adhesive time to evaporate properly.
Step 5 – Secure the Pieces Together
After the allotted waiting period, carefully bond the items together. Make sure the pieces are aligned. Once you have put the pieces together, do not move them.
If the surface shows some bubbles, apply pressure to remove them. Rress from the center and move the pressure toward the end.
Step 6 – Clean the Overspray
If you have any overspray, immediately clean this area to prevent the glue from drying. With a wet rag, wipe any surface that has overspray. Use the adhesive remover for any hard-to-clean surface.
