How to Use Mildew Resistant Paint
Black mildew in the corner of a wall
  • 2-10 hours
  • 0-200
Mildew resistant paint
Mildew resistant primer
Paint brush
Foam brushes
Paint roller
Paint tray
Sponges
Bucket
Mildew remover
Soft bristle brush
Dehumidifier
Paint brush
Foam brushes
Paint roller
Paint tray
Sponges
Bucket
Mildew remover
Soft bristle brush
Dehumidifier
If you are trying to convert your basement into a livable space, mildew resistant paint is a necessity. The natural dampness of the basement, along with the coolness of the concrete can cause mildew and mold to grow. Mildew resistant paint is specially treated to prevent and stop the growth of mildew and common molds. It can also be used in common mildew areas like bathrooms and kitchens. Using mildew resistant paint sounds like it should be easy, and it is, but it requires more steps than regular paint. The information below will show you how to properly apply the paint.
Step 1 - Clean the Walls
Prior to using mildew resistant paint you first need to clean the walls. This is especially the case when there is already evidence of mildew or mold growth. The least amount of mildew on the wall when you begin will better ensure the success of the mildew resistant paint. Choose a good, non-toxic mildew and mold remover. These can come in concentrated forms so make sure to read the label and mix it with water as the instructions discuss.
Wet a sponge with the cleaner and begin wiping down the walls. Work in small sections. Once one section is wiped down; use the soft bristle brush to scrub the wall. Spend extra time on areas that contain mold or mildew. Pay close attention to the bottom of the wall as well as the top and corners. This is where mold and mildew will form. Plug in the dehumidifier and allow it to remove moisture from the area. This will also cause the walls to dry quickly and evenly.
Step 2 - Prime the Walls
basment
When using colored paint on concrete walls you should always prime the walls first. Mildew resistant primer is used because it not only enhances the properties of mildew resistant paint but is generally thicker. This means that the top coat of paint will be able to be spread in one coat and will provide a coverage that is more consistent.
This also means the top coat will go on evenly. Use the foam brushes to apply the primer to the wall. It is best done by dabbing the primer on and not using a stroking method. This allows you to fill pits and small holes. Make sure the dehumidifier is turned on so the primer can dry evenly.
Step 3 - Apply the Mildew Resistant Paint
You will notice that mildew resistant paint is often thinner than primer that contains the same chemicals and properties. Make sure the primer has dried completely before you begin to paint the wall. Stir the mildew resistant paint to make sure it is properly mixed. Pour some of the paint in a paint tray and use the roller to apply it to the wall. To make sure you get all of the critical areas use a paint brush to complete the bottom and top of the wall as well as the corners.
