How to use Nitrogen for Tire Inflation
Nitrogen Canister
Valve for inflating tires
Nitrogen Canister
If you drive a car on a regular basis then you are probably already aware of the importance of good car maintenance, nitrogen tire inflation can lengthen the health of your tires.
Tires must be inflated properly according to your owners manual for a number of reasons. First, this will improve the efficiency of your vehicle. Correct inflation will also make your car much safer and reduce the chances of an accident. There are many people who swear by using nitrogen for tire inflation.
Nitrogen is an inert gas which means it doesn't contain any dirt, moisture or dust. It's also a very safe gas which means it will not explode if you are ever in an accident. Many people find their car operates much more efficiently with nitrogen in the tires, which also results in a cost saving.
Step 1 - Check the Condition of Your Tires
The very first thing that you need to do is check the condition of your tires. It's vital that you spend time looking at your tires before you fill them up with nitrogen. Any nicks or cuts in the tire walls or tread could affect the integrity of the tires. There is no point putting nitrogen in them now if you will only have to replace the tires in the near future.
Step 2 - Finding Nitrogen
Nitrogen tire inflation kits aren't difficult to find. They can be purchased from a wide range of car dealers and garages all over the country. Nitrogen is actually quite affordable and won't cost much more than inflating your tires with air.
Step 3 - Inflating your Tires
Inflating your tires with nitrogen is actually pretty easy, especially if you purchase a kit with a nitrogen cylinder and the valves, which are used to connect it to your tire. Never use any other gasses other than those designed specifically for tires. Using another type of gas could cause accidents.
Check your vehicle's handbook for the correct pressure for your tires. Every car is different and the weight you are carrying will also affect the tire pressure. When using nitrogen the tire pressure should be exactly the same as when using air.
Inflating tires with nitrogen is just as easy as inflating them with air. Nitrogen doesn't contain any moisture or dust, which means that they are less likely to cause damage to your tires.
Step 4 - Maintaining the Nitrogen Tires
The final thing you need to do is keep an eye on your nitrogen tires. It's possible to check the levels of nitrogen in the tires and then top it up if needed periodically. If you ever notice that your tires are losing pressure, you can safely top them up with normal compressed air.
