How to Weatherproof Your Outdoor Kitchen
Stainless steel appliances
Outdoor cabinets
Canopy
Porcelain tile
If you are considering installing an outdoor kitchen, there are a number of different things that you are going to need to think about first. Since your kitchen is going to be outside, you are going to have to put some thought into how you are going to prevent any damage from weather. Here are a few things to consider about how to weatherproof your outdoor kitchen.
Step 1 - Flooring
One of the first things that you will need to start out with in your outdoor kitchen is the flooring. You want to make sure that you choose a product that can hold up to the weather. Many people make the mistake of trying to put standard ceramic tile outside in their outdoor kitchen. If you do this, there is a good chance that moisture is going to get down into the ceramic and when it freezes, the tiles will break. You should only use ceramic tile if you live in a warm climate that never gets below freezing. Instead of using ceramic tile, you might want to consider using porcelain tile. Porcelain does not absorb moisture and it is very durable. On top of that, you can create any type of look that you can imagine with porcelain tile.
Step 2 - Cabinets
Another important aspect of your outdoor kitchen is the cabinets. You want to pay special attention to the cabinets so that you can prevent them from being damaged by the weather. If you use regular wood cabinets outside, you are most likely going to run into problems if you live in an area that gets a lot of rain. Instead of using regular cabinets, you are going to want to purchase cabinets that are made for outdoor use. There are a number of companies out there that utilize the same types of cabinets that they use in marine environments. This way, you can allow the cabinets to get completely wet and you will never run into any problems.
Step 3 - Canopy
When you are creating an outdoor kitchen, it is also important that you put up some type of canopy overhead. It is going to help limit the amount of rain or snow that can get on the contents of your kitchen. In addition to this, it is going to limit the amount of direct sunlight that gets on your kitchen as well. Depending on what type of countertop material you have, you are going to need to be careful with direct sunlight. For example, if you have a granite countertop, the sun can negatively affect the resin within the granite.
Step 4 - Stainless Steel
You should most likely invest in stainless steel appliances and a sink for your outdoor kitchen. Putting in a stainless steel grill and refrigerator is going to limit the amount of impact that weather can have on these items in your outdoor kitchen. They will also be very easy for you to clean and maintain.
