Husky Pressure Washer
When browsing the Husky pressure washer selection, take a look at both the DeckMate 2-N-1 electric pressure washer as well as their more-powerful gas-fueled pressure washers. Suitable for a wide variety of applications, Husky pressure washers excel at light-duty and heavy-duty domestic cleanup jobs. While they don't have the power necessary for professional use, a Husky pressure washer will accomplish just about any home task, from gutter, window and vinyl siding cleaning to moss removal on walls and patios. Wash automobiles and other vehicles quickly and easily and use the pressure washer to blast dried mud, concrete residue or light grease from a driveway or sidewalk.
Husky DeckMate
The Husky DeckMate 2-N-1 is a 1400 PSI electric pressure washer with a water flow rate of 1.3 gallons per minute. It is a low-profile unit with built-in casters, a maintenance-free pump and an angled slot in which to store the trigger gun. The nozzle of the DeckMate spray gun features a double-headed design offering both standard spray and rotating spray modes.
Husky Gas Pressure Washers
Husky gas pressure washers include 2600 PSI and 3000 PSI models with a 2.4 and 2.5 GPM flow rate, respectively. Both gas units feature a powerful axial cam pump, a high-strength tubular steel frame and durable 12-inch wheels. The 2600 PSI model is built with a 173cc Kohler engine, while the 3000 PSI model features a 187cc Honda engine.
Accessories
The gas pressure washers both come with an on-board spray gun with wand and nozzles including fan-spray, soap dispensing and turbo varieties. A detergent storage container is included as well. Gas pressure washers can store up to 1.4 gallons of fuel and weight approximately 65 pounds. Their walk-behind design allows for easy maneuverability. The DeckMate 2-N-1 unit goes for around $140, while the gas-fueled pressure washers cost between $300 and $400.
