Hydronic vs Electric Radiant Ceiling Heat Hydronic vs Electric Radiant Ceiling Heat
When you are trying to decide between hydronic and electric radiant ceiling heat, it is important to first have some information about both of them. What are the pros? What are the cons?
With this particular method, the power of electricity is used to heat areas of your home up. This is something customizable and made to heat only certain areas of your home at various times.
Benefits of Electric Radiant Panels
The primary benefit being it could save you some money. With the electric approach, there is no need for a blower to run in order to circulate the heat around the house. This not only means that you have no filters on the blower to worry about regularly replacing, but also that you do not have to use electricity to run the blower motor.
Another benefit also ties in with not having to use a blower. This reduces your chances for things like pollen and dust being circulated through the room or suffering from drafty areas. This could make allergies a lot easier to deal with.
Disadvantages of Electric Radiant Panels
A disadvantage of choosing this route is the lack of cooling. If you were to install a central air conditioner, this would remove many of the benefits of the electrical radiant panel.
Hydronic Radiant Ceiling Heat
With this particular heating method, a boiler is used. Hot water is sent through a series of pipes or tubes to heat the designated areas.
Benefits of Hydronic Radiant Panels
Like with the electrical approach, there is no need for a blower. This will save you money since you won't have to use electricity to power it and also because you will not have to worry about filters. It will also help prevent the spread of dust and other allergens, along with helping to lessen drafty areas.
Another benefit of using the hydronic approach is that it helps to prevent snow or ice from forming and gathering. If you live in a particularly cold area, this would be something that would be very useful to have.
Disadvantages of Hydronic Radiant Panels
One of the biggest concerns when using hydronic panels is the possibility of leaks. There is always the possibility that something will go wrong with the pipes holding the hot water, which would lead to it spilling into the walls.
