Ideal Growing Conditions for Winter Squash Ideal Growing Conditions for Winter Squash
Winter squash is one of the most popular vegetables grown in home gardens across America. There are many different varieties of this vegetable, each with its own unique use and flavor. Some of the more common varieties are the buttercup, acorn, hubbard, spaghetti squash and butternut. These are great in vegetable dips, soups, and as toppings. Even its seeds are delicious. Growing winter squash is popular because once they are harvested in the fall, they can last all through the winter season. If you are thinking of growing squash in your vegetable garden, consider the following steps to create the ideal conditions.
Soil
The squash is not picky when it comes to soil and will thrive in almost any type. Just make sure your soil is well drained. Adding some organic matter or well rotted manure into the soil will help improve the health and drainage of the soil. Organic matter is rich in beneficial soil bacterias, which play a vital role in restoring the soil ecosystem.
Light
Areas that receive full sun are best for growing squash. Planting in a predominantly shady area will slow the flowering process and cause the fruit to mature at a slower rate. You should also leave plenty of space when you plant so the plant gets adequate air circulation when it begins to extend.
Water
The winter squash does not require much water. It grows best in soils that are not too wet, so be careful not to over-water. It is best to water the plants thoroughly each time instead of watering more frequently. You should wait until the soil begins to dry out before you apply more water. This will enable deeper infiltration of water into the soil. Drip irrigation systems work very well for the winter squash. This also prevents water from getting onto the plant leaves, which prevents some common diseases. You can start to cut back on watering when the fruit begins to mature. Otherwise, once a week watering is sufficient during dry weather. You can stretch out the spacing in between watering when the weather is not as dry.
Fertilizers
Avoid using chemical fertilizers on your crop. It is best to use organic fertilizers or compost. These encourage healthier soil, which is a fundamental requirement to successfully grow your winter squash.
