Improve The Look Of Your Wood Sliding Doors Improve The Look Of Your Wood Sliding Doors
Wood sliding doors can greatly enhance the beauty of your home. The color and richness of your wood sliding doors should be maintained. Adding decorative accents or staining the wood is a simple way to improve the look of your wood sliding doors.
Wood Carving
Wood doors are a perfect place to add some detail to the room. Carving on the door can provide an elegant look to the room. To get started with wood carving, you should plan out your design on a soft wood material. This will help you make sure that the design looks exactly the way that you want. Wood carving is an artistic pursuit and you should make sure that you have the skills and the proper design before you start carving up your wood sliding doors.
You also need some good carving tools to get started such as a utility knife, pick and chisel. The design can be drawn directly on the door or on paper and transferred to the door. A simple design will work best if you are just starting with your wood carving.
Stenciling the Door
Stenciling is a wonderful way to add some color to your doors and make them stand out in the room. When you change the color scheme in the room, add those colors to your wood sliding doors with the use of a little paint and a stencil. Choose a design that fits in with the décor of the room. Stencils can look faded and well worn into the wood.
Stain the Door
Changing the color of the door is one of the ways that you can improve on the look of the room and the door. The color of the door can be made to coordinate much better with your room if you choose a different color stain. Take the door completely down so that you can completely stain the door without staining the walls and hardware.
Remove the old stain from the door by sanding it completely. Depending on how far the stain has penetrated the door, you may have to sand deep to get to the original color of the wood. If you are removing a darker color so that you can stain with a lighter color, it might be difficult.
Change the Hardware and Accessories
You can improve the look of your wood sliding doors by changing the handles and the hardware. A new more intricate design might bring a brand new look to your doors. Take some time to explore all of your options when you are searching for new door accessories.
There are a number of things that you can do to improve the look of your sliding doors. The color, texture and design of the doors can all be altered to give the look of the door something brand new. When redesigning a room in your home, changing the doors and details of the room to coordinate with the new look can bring together the whole look. Plan all of the details in advance.
