Infrared Patio Heater Pros and Cons
A infrared patio heater can provide you with a number of unique benefits. However, it also has a few drawbacks that you should know about. Here are some of the pros and cons associated with infrared patio heaters.
Low Cost
One of the major advantages that you will get by purchasing an infrared patio heater is a cheap initial cost. It is traditionally less expensive to install this type of heater than other heaters. With an infrared patio heater, you can simply plug it in to any electrical outlet. By comparison, many people purchase gas heaters and then have to pay the additional cost to run a gas line to the porch. This will not be necessary when you purchase an infrared style.
Low Energy Use
In addition to paying less on the front end, you will also typically pay less throughout the life of the heater. Infrared patio heaters consume less electricity than other similar types of heaters. Therefore, your utility bills will be less when running this type of patio heater.
Focused Heat
An infrared patio heater will allow you to create a focused source of heat. Other heaters attempt to disperse heat throughout the entire area. With an infrared heater, it will basically shoot a beam of heat at whatever it is pointing at. This makes it an ideal solution to heat small spaces without wasting a lot of heat throughout the area.
Improve Health
Infrared heaters also can provide you with certain health benefits as well. Infrared heat is known to go deep in to your skin. With this type of heat, you will actually improve your circulation which has a number of benefits to your health. This is very similar to the benefits that are received by being in the sunlight. However, you will not have to deal with the harmful rays from the sun on your skin.
Not Designed for Large Areas
With this type of heater, you will have to be aware of some drawbacks with it as well. For one thing, the heat typically goes in a straight line out of the heater. Therefore, if you are in the direct line of heat, you will be warm. However, if you are not in line with the heater, it will still be cold for you. This means that this is not the ideal solution when you want to provide heat for many people on the patio area.
Maintenance
You will also have to worry about ongoing maintenance issues with this type of heater. In order to work, the infrared heater has a special light bulb. This type of light bulb will typically work for about 4,000 hours. This means that you will get about 2 to 3 years out of a particular infrared light bulb. At that point, you will have to purchase a new infrared bulb for replacement.
