Infrared Sauna: Choosing Between Carbon and Ceramic
Whenever you are choosing an infrared sauna, you will find that your main 2 options are between ceramic and carbon. There are several different things that you will have to keep in mind to make sure that you are able to get the most out of your sauna. Do your homework and read up on what each choice will be able to offer you. The more that you understand about what each one can provide, the easier it will be for you to make the best decision possible for you.
Carbon
You will find that there are several infrared saunas that are made with multiple thin fiber panels that are made of flat carbon. There are many locations in the sauna that will give out a uniform infrared heat. Occasionally, the fiberglass for the protection as well as the covering is enclosed. You fill find that the carbon panels are flexible and are actually much less likely to break whenever it is in transit. This is one of the biggest issues with infrared saunas. Whenever they are being brought home, they will become broken while traveling. These types of carbon saunas have a wide and flat shape and are able to have a quality heating element for you because of this large and flat shape.
Ceramic
You will find that ceramic sheets also have a bigger surface area that are built into the inside walls. This will be on all sides of your sauna. The biggest difference is that ceramic is much more delicate in comparison to carbon. It will need to be taken care of much more whenever shipping is happening. Installation will also have to be done carefully so as not to break the ceramic. Ceramic is also more expensive than carbon. The reason that they are more expensive is because they are able to provide a true far infrared type of radiation. Carbon panels are only able to heat up and give out just a simply type of radiant heat. This is something that can cause perspiration, but you will not be able to get the same benefits with soft tissue as you would with ceramic heaters.
Overview
Basically, what you will need to keep in mind is that a lot of places will consider the ceramic to be more superior to the carbon. However, while it has a higher emissivity, which is basically its ability to radiate infrared to you it is not a lot higher. The carbon’s ability to provide infrared heat to you is not much lower. It is also much stronger and is less expensive. This is something that you should keep in mind. You will find that the more that you are able to get out of your infrared heater, the better. However, it is important to understand that the carbon can provide to you not much less than a ceramic. Most people will never be able to tell the difference. This means that if you are worried about price and getting it shipped to you safely and installation going smoothly that carbon is the right choice for you.
Carbon
Ceramic
Comparison
