Installing and Using a Wall Panel Heater
A panel wall heater provides a more efficient heating system to the home or a room without having to spend too much on energy consumption. A panel wall heater is easy to install and does not need to fill up a large space in a room because of its relatively small size.
Installing a Panel Wall Heater
The installation process for a panel wall heater does not require a professional because it usually comes with its own installation kit and installation manual. The installation process only requires drilling holes on the wall and mounting it using screws provided in the kit.
The process involves finding a good location where the heater can be mounted. It does not have to be high above the wall. Make sure to install it at a convenient location where the installation can be done easily. Since the panel will not produce scorching heat, it can be placed at a lower part of the wall. Install it near a power outlet in order to avoid using extension cables.
After finding a suitable location, use the template that comes along with it to mark the holes to be drilled. Make sure to find the studs on the wall first to ensure that the device will be mounted securely. Drill the holes according to the required depth and diameter and begin the installation. The installation simply requires holding the panel into position while tightening the screws. If a back plate comes along with it, install it first onto the wall.
When the installation is complete, connect the heater to a power source. Adjust the heater to the desired temperature and enjoy the heating effect. The homeowner also has the option to paint the heater to match the interior design of the home in order to conceal its whereabouts.
Using the Panel Wall Heater
In order to use the heater effectively, make sure to provide constant care and maintenance to ensure long use. First of all, it is important to understand how the panel works. The panel heater uses the convection technology. It allows air to be heated at the back portion space between the wall and the panel. The design creates low noise and more efficient use of energy. In order to allow the panel to work efficiently, always follow proper maintenance procedures.
Use the heater only when needed. Constant heater activity, like in other electric appliances, tends to lower the efficiency, especially after long periods of use. Therefore, make use of the appliance only during very cold seasons. Unplug the device when not in use. If the heater has to be uninstalled for storage, make sure to clean it first to remove the dust and other debris.
Inspect the heater as well regularly to check if it is heating properly. In case the heater fails to work, have it repaired or buy a new one. Never allow a dysfunctional heater to run in the house to avoid hazards.
