Quick Advice to Make Installing Basement Window Covers Easy Quick Advice to Make Installing Basement Window Covers Easy
Basement window covers will help keep an egress window from accumulating debris. They also aid in regulating the basement temperature; furthermore, they protect vulnerable windows from security issues. Installing a basement window cover isn’t difficult if you take follow this advice before starting the project.
It is very important to measure correctly. It is much easier to install a window cover when the cover is properly fitted before you install it. Most window covers can be cut to fit, but it's going to save you a lot of time if you order the correct size.
Before you start drilling and pinning the brackets and cover in place, have someone help you set the cover in place. Doing so will allow you to mark the exact spots you need to drill. It will also alert you to any potential obstacles that may hold the installation process.
It's much easier to install basement window covers if you have plenty of room to work. Make sure the area is clear of debris, both inside and outside. Make sure you both have room to work.
