Interior Aluminum Wall Cladding Interior Aluminum Wall Cladding
Interior aluminum wall cladding is another great option to choose from when deciding what to do with your home. Whether you are a new home owner and decorating for the first time, or doing a remodel, it is important to learn all of the facts before jumping right into a new project or material. Here are a few things that you should know about interior aluminum wall cladding, before you get started on your next home task.
What is Wall Cladding?
The first thing to address is wall cladding in general. This basically means a siding or covering for your wall and in this case, it means that the siding is aluminum and inside of your home instead of out.
Benefits of Aluminum Wall Cladding
There are several benefits that come with installing interior aluminum wall cladding. Some of which include durability, protection, easy maintenance and overall decor. Aluminum overall is an extremely durable material and even though you aren't using it outside, it is nice to have a sturdy surrounding in your home as well. Maintenance and protection go hand in hand as the wall is pretty easy to clean and at the same time, it is hard to do any damage to. This is a great wall siding for families with younger children. It has a sleek and modern look that also allows you to live freely and not as though you are in a museum.
Another great thing about this type of material inside of your home is that it helps to reduce noise and echoing. This is an especially great siding option for hallways, playrooms and basements where you have a lot of traffic or gathering going on. The design aspect is newer and you can find many different things to compliment this type of wall choice and it is versatile enough for any room. This type of material is also great when it comes to insulation and efficiency as it can help to keep the costs down for your electric bills.
Disadvantages of Aluminum Wall Cladding
While there are many advantages to the aluminum wall cladding, there are also a few downsides as well. The biggest con is that this type of material can be expensive, especially if you have a large area that needs to be remodeled. Another downside that goes hand in hand with the cost is the fact that aluminum wall cladding on the interior is a relatively new design idea. This means, that if you are remodeling, it is pretty likely that you will need to update much of your home to allow this style and decor to flow from room to room. It would clash to see wood paneling from 1970 in one room and then a modern update of aluminum wall cladding in the next. So if you do not have a bigger budget to update walls accordingly, this may be a burden on you financially and maybe not the best option.
