Introduction to Bamboo Plywood
Bamboo plywood is a gorgeous alternative to traditional lumber. Here is some basic information to get you started if you are looking into it as a building material.
How Bamboo Plywood Is Made
Bamboo plywood is made by lining thin strips of bamboo parallel to one another and heat pressing them together. Often they are 3 or more layers thick for stability. Bamboo plywood comes in different grades, which are determined by when the bamboo is harvested, the age of the plant, and the amount of rain it has gotten, among other environmental factors which affect the hardness. It can be bought in a wide range of finishes or, if you want to do it yourself, you can buy it unfinished. Bamboo will take most regular stains.
Advantages of Bamboo Plywood
Bamboo plywood is known for its unique and beautiful look, but there are other reasons to consider it. It's multi-layer design makes it up to 3 times more durable than oak and it is more resistant to warping than other traditionally made woods. Bamboo also grows very quickly, making it a renewable resource and ideal for an eco-conscious do-it-yourself-er.
What Bamboo Plywood Is Used For
Counter tops and cabinets made of bamboo plywood will add an individual touch to any kitchen. It is also easy to clean making it a good option for flooring. Because bamboo is processed during it's manufacturing it is resistant to termites and ants, making it good for outdoor projects as well.
