Is a brick or concrete path more durable?
Between a brick and concrete path, brick is more durable. It can withstand more pressure, and would be the perfect material to use for the paths outside your house. Especially if your pathways experience heavy foot traffic and other heavy objects, using brick would be the better option. It also requires less maintenance, which could therefore save you a lot of money in maintenance costs during its lifetime. Since bricks are more solid in structure, compared to concrete, they will last a lot longer and require fewer repairs. So, when choosing between a brick or concrete path, if money is no object, go with the brick option.
