Is a Wood or a Plastic Rain Barrel Better?
If you are trying to decide between using a wood or plastic rain barrel, you need to consider a few different factors. In most cases, a plastic barrel would be the best option. Plastic will not have any issues with deterioration over time, even when exposed to lots of moisture. If you use a wooden barrel, the wood can start to rot if water stays in it for an extended period of time. It could also lead to problems with mold after a while. Plastic may be a little more expensive, but it is well worth it in most cases.
