Is roll-out garage flooring durable? Is roll-out garage flooring durable?
Roll-out garage flooring is considered to be durable compared to a lot of the other flooring options that you could use. Roll-out garage flooring is very thick and hard. It also comes in large sheets that are connected together. You will not have to worry about the seams coming apart, and the surface of the flooring wears well also.
The one issue that you might run into with this particular type of flooring is when you drop something sharp on it. If you drop a knife or a screwdriver on it, you could cut through the top.
