It is safe to have kitchen sink plumbing attached without a slip joint? It is safe to have kitchen sink plumbing attached without a slip joint?
In the event that you need to replace kitchen plumbing, first determine how big of a job you have. If it is a small job then DIY is the way forward as plumbers charge huge labor rates. However, if it is a large job, then it is worth biting the bullet and hiring a professional because water damage costs a lot of time and money to repair. Attaching kitchen sink plumbing without a slip joint is poor workmanship. While initially the plumbing may look secure, it will cause problems in the long run. A common problem to arise will be leaking, which will cause corrosion and dampness, possibly leading to mildew problems.
