Kia Repair Manual: Window Defroster Repair Kia Repair Manual: Window Defroster Repair
If you are having trouble with your window defroster, then you may consider searching in your Kia repair manual for an answer. This can be more difficult than it looks, however, and you may soon find yourself stuck with a defroster which doesn't work properly. In order to fix this problem, you will need to know what you are looking at.
Check the Manual
Take your Kia repair manual off the shelf, and locate the fuse, the defroster grid, and the defroster switch. You will need to check each part of these in order to establish what part is not working.
Check the Fuses
With any electrical equipment, the fuses are a great place to start looking for problems. Fuses can blow if there is too much electricity flowing to them at once, or may just work themselves loose over a number of years. If you find any problems with your fuses, replacing them is the simplest solution.
Check the Defroster Grid
On your Kia Repair Manual, look for the terminals on your defroster grid. These could be at either the top or the bottom, and are easily broken or worn out. If you do find the terminals have been broken, you can repair them quickly by using a dab of glue.
