Laminate Vs. Granite Countertops
Can you buy a laminate granite countertop? Unfortunately, the two are very different and each have some advantages and disadvantages to consider. If you are contemplating purchasing either of these kinds of countertops, read the following information to better educate yourself before your purchase.
Pros and Cons of Laminate
Laminate can be up to ten times cheaper than granite, as laminate is a mass produced product. It’s much lighter than granite too, which makes it easy for a do-it-yourself enthusiasts to install without specialist tools. The only disadvantage of laminate is its durability. If the countertop is not looked after properly, chips and stains can look unsightly and may be harder to repair.
Pros and Cons of Granite
Granite varies enormously in its color, and the same piece of stone can take on a different look depending on the lighting in the room. So the major advantage of a granite coutnertop is its appearance. Granite countertops are also virtually indestructible. For an area of heavy use, granite will prove to be much more durable than laminate. However, the downside is that you have to pay a lot for this beautiful, durable product in addition to the labor it will take to install it. That is, unless you have the tools to properly put it in place.
Which to Buy if You are on A Budget
The technology for producing laminate countertops is now so sophisticated that granite effect designs are virtually indistinguishable from the real thing. So, you can get the same granite look without the price. Therefore, if you are on a budget, laminate will be the better choice.
